Bike cleaning
kw4570gov
Bike cleaning
Post by kw4570gov »
I know this has probably been asked already but, what brand or type of cleaner does everyone use to wash their bikes with? I have a power washer too. I need something to not only clean dirt and mud, but the oily residue around the head/pipe junction.
Thanks
Kent
I used simple green when I do wash 'em :lol:
The spooge is really hard to get off, Ive heard of people using oven cleaner but that scares me on alloy.
Anything Alkaline based will stain the alunimum.
Simple Green will take any muck off safely.
I used some of that " Spray on Wheel Cleaner" stuff too.... made for aluminum... no issues.
X2 on the simple green
I use simple green for the whole thing, but then a little castrol superclean on the spooge and such. its a little tough on the AL, but if you wash it off quick, you wont have any probs. I wouldn't spray then crack open a beer and take out the garbage, then rinse. the stuff is really tough on oil, so it should loosen it up pretty quick.
Xylicon
Post by Xylicon »
Regular Dawn dish soap, and I use Comet to brighten up the white plastics.
Edit: Am I the only one that doesn't get spooge?
97 CR500, 94 CR250, 87 CR125
Soft Scrub w/ Bleach rocks on the white plastic.
I suggest if you get spooge, fix the leak! I used some high temp silly cone on several spooging spots and the spooge has been eliminated. As for using a pressure washer, I say be carefull, the water will get into spots you don't want it to, like bearings and seals. And I like Gunk for tough stuff, it's the old standard.
Wash?!?
Say what now?
kw4570gov
Post by kw4570gov »
I agree about the pressure washer, mine has a setting that fan sprays with less pressure than my hose sprayer that I use to just wet the bike and to wash off the soap.
As for the spooge, I have never had a 2-stroke that did not leak a little at the pipe cylinder junction.
Thanks for all the information, now I just have to get out there and clean up the beast.
Kent
you need to take care of the spooge problem, its a combination of running too rich and not having the pipe sealed. If you get the pipe sealed (I use permatex ultra copper RTV) it will be easier to tune, since the leak that is letting spooge out is also letting air in, which is probably why its running fine even though its too rich.
AlisoBob wrote:Soft Scrub w/ Bleach rocks on the white plastic.
portedandpolished wrote:And I like Gunk for tough stuff, it's the old standard.
I use the same stuff. Theres also Oil Eater from Costco - It says its enviro-friendly so I didnt think it'd work, but it actually works quite well. Even removed old oil from my concrete! Super Clean is good stuff too, but it will dull your plastic and aluminum. And you know that impossible to clean off spooge on your plastic? Use Plexus after washing. Cleans it off and makes your plastic real shiny and smooth. :cool:
And Danny - you never clean your bikes! LOL!
well, I don't want to over wash a "dirt bike" and get a bunch of water in the bearings. BTW, you still haven't pulled the swigarm bolt on your 250, have you?
dude, is that the same costco stuff my mom bought like 5 years ago to clean up my oil spills??? LMAO!!!
Yeah, I ran out of that stuff and found it again - so I bought it. It really works quite well!
yeah, I thought I saw it on the shelf last time I was there.
kw4570gov
Post by kw4570gov »
Not to change my own topic but if I do seal up the spooge leak then does the spooge just fill up my pipe or will it blast on through with the exhaust?
Kent
the whole idea is to stop it from spooging at all. it spooges from being too rich. if you seal the pipe, and lean out the jetting (most likely needle or pilot) it will run a lot better and not make a mess.
kw4570gov
Post by kw4570gov »
Even if my bike is bone stock just like it came from the dealership it is jetted to rich?
Kent
yup, they jet them rich from the factory. better to see some spooge, than have people making waranty claims on improperly tuned bikes.
the stock needle majorly sucks, too rich down low and too lean up top. A lot of us run Bob's DGN or R1472N needle and love it.
anything carburated does require constant adjustment with elevation changes, temperature changes, riding environment/style changes and different oil ratios to run properly. trust me, if you got it dialed in, you would have a very noticeable difference in performance, running rich slows you down.
kw4570gov
Post by kw4570gov »
Thanks for the info, I may have to look into a jetting change in the future. She runs great now I cannot imagine more power!
Kent
Well post up your elevation and temperature range you ride in. Then we can get you in the ballpark main jet wise. Post what ratio you mix at, and any mods you have also.
my first suggestion is always DGN needle, junk that stock 1368, what a terrible idea on hondas part. I couldn't even get my cousin's (hoofarted) bike to run right on it, so we just ordered the DGN and it runs tits.
I'm not talking about the main jet at all anyway, no one is WFO on a 500 long enough to cause a spooge problem from the main, its all in the needle. With a better needle, you would get better throttle responce and better 1/4-3/4 throttle power, which is where it counts if you ask me.
Way better mileage too....
kw4570gov
Post by kw4570gov »
Don,t know what alt. I am at, I am in north Louisiana so I cannot be to high. Ride mostly in the summer with temps between low 80's and high 90's. My bike starts and runs great, I just noticed a little spooge after a short ride.
Thanks
Kent
