01 crank in a 85 ?
vintage mike
01 crank in a 85 ?
Post by vintage mike »
will a 01 crank work in a 85 using a cylinder spacer? also any problems running a +2mm piston? Thanks
abrracing
Post by abrracing »
Nobody knows if this is possible??
cylinder deck spacer from forum member tecrider or from the cometic company will let you use the 1987-01 crank in 1984-86 cases.
+2mm is getting pretty damn thin on the cylinder sleeve for 1985-88 motors
abrracing
Post by abrracing »
thanks for the info, good to know.. i have one of tecriders spacers incase i ever need to do this on my 85'
