ring end gap
- other
ring end gap
Dumb question time . . . . Brand new stock jug 89.0 bore, brand new stock cast piston, brand new standard rings . . . . wash the Honda honey off the bore, slip the rings in with the slug so they sit square, end gaps measure 19 and 20 thou. . . . . is this about right ? I know there was a formula that stipulated the end gap as a percentage of bore circumference, but I'm buggered if I can find it ! Just want to make sure this engine is as safe as possible. Any opinions ?
I'd have looked for .018", go with the .019"
have you measured that cylinder to see that its skirt is proper size?
This is one thing that piss' me off sometimes.
The end gap in the manuel says .018-.020 max. I think there is a minium of .014?
I have yet to see an end gap of less than .018 with a fresh bore and rings.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
Re: ring end gap
I know the formula for a forged piston is usually .004" for every inch of bore.. for cast i'd just use the same... can't hurt... i've took a kx125 engine apart for a customer that had a ring end gap of .020" and it ran fine.. lol thats no joke.other wrote:Dumb question time . . . . Brand new stock jug 89.0 bore, brand new stock cast piston, brand new standard rings . . . . wash the Honda honey off the bore, slip the rings in with the slug so they sit square, end gaps measure 19 and 20 thou. . . . . is this about right ? I know there was a formula that stipulated the end gap as a percentage of bore circumference, but I'm buggered if I can find it ! Just want to make sure this engine is as safe as possible. Any opinions ?
scooter5002
