Good day,
I would like to upgrade the carb and reed cage and possibly the head on my 89. I currently am running a FMF fatty pipe and a Bills silencer. I will list everything I was thinking about going with. If someone would please chime in and tell my if this is a good combo or of there is something better I would appreciate it greatly,
1. BOYESEN POWER REEDS
2. 39MM PWK
3. Cool Head
Need advice with new carb and reed selection
add a moose 10mm (3/8") reed spacer to the list.
I can make the stock heads chamber work better than the coolhead by altering the squish distance and the band widths, add a decompressor to it for a total of $245.
don't buy anything except the 39mm pwk
i'd set up the head how ever you'd like
BrianPaul69
You might want to look into this setup :
http://www.ebay.com/itm/181184205826
and I would not recommend the V-Force reeds. I removed them from both my bikes and replaced them with a Boyesen Rad Valve. I installed this Pulse setup on my 95 CR500 and I love it. Roosty can tell you about it also.
