Moose Racing Torque Spacer
jbird_710
Post by jbird_710 »
I searched but didn't find any details - excuse me if this is a repost.
Has anyone used one of these on an '01 engine? If so, did you notice any difference and did you have to re-jet for it?
Jay Birdsong
I've seen this too and am curious.
jbird_710
Post by jbird_710 »
Roostius said he recommends it with his porting and that it should help even a stock engine. I put one on my bike yesterday and ran it a couple of passes on the street in front of my house. Didn't seem to cause any adverse effects and jetting seems fine. Will take it out to the track this weekend to see if there's any noticeable difference.
Jay Birdsong
Homeskillet
Post by Homeskillet »
Didn't really notice any difference in either performance or jetting, but I left it in place because the fitup is much better w/ the airbox boot. Have heard that on a 250 you need to space the pipe as well to get the benefit, wondered if any of that applies to the 5 zero zero.
jbird_710
Post by jbird_710 »
Didn't notice any difference on the track but the bike won't idle now. May need to tweak the air screw a bit.
Jay Birdsong
Kuma
Post by Kuma »
seems odd that it would effect the idle, no air leaks?
jbird_710
Post by jbird_710 »
Doesn't seem to have any. I would think it would idle up higher (run lean) if there were. Performance seems no different - low, mid, and top end of the rev spectrum feels the same. No difference in how the power comes on compared to without the spacer. Will work with it tomorrow evening.
Jay Birdsong
other
Post by other »
jbird_710 wrote:Doesn't seem to have any. I would think it would idle up higher (run lean) if there were. Performance seems no different - low, mid, and top end of the rev spectrum feels the same. No difference in how the power comes on compared to without the spacer. Will work with it tomorrow evening.
Easiest way to find an air leak is start her up, run it at constant revs as low as possible, and spray an aerosol can (just about anything will do, penetrating oil, Aerostart ether, flyspray . . . ) around the carb and airboot. If it's leaking, the revs will rise. Word of warning, if you do use one of those ether engine starter sprays, keep the overspray well away from the plugcap !
Kuma
Post by Kuma »
Sounds like you found a electrical leak :lol:
