My new A/F build
lambofgod85
My new A/F build
Im starting to building my cr500 A/F and needed to know some info on the chassis type. Im using a Crf450 2002. Is that model frame a Gen3? Are the crf450 2002 to 2004 have the same cosmetics? Also has anyone done this conversion to the same model as mine? Thanks
Yes 02' is a gen 3... believe from 02'-07' is the same for cosmetic's, but do your research! Take some time and read though the sticky's at the top of the forms as they often have all the general things your looking for such as;
http://www.bannedcr500riders.com/board ... php?t=1840
lambofgod85
And if you have some time to kill there is always this guy:
http://www.youtube.com/watch?v=1HJz5WZldH4
Its a gen 3 CR250 frame but a lot of the work is the same and he is pretty entertaining...
lambofgod85
Thanks mate. Yeah i have been watching his build part by part over the last few weeks. Its good to see what others do. Im a boikermaker/ fabricator at one of the sugar mills so i have almost everything i need to complete my build as in tig welding machines, guillo, drill presses, centre lathes, milling machines, etc. And lots of time. Im looking forward to it.
lambofgod85
Update on the progress of my gen 3 cr500 a/f. I got the 5'' grinder out other day and started to cut out cradle frame from the Top of the Y frame to the foot peg, I am going to replacing the hole cradle frame with 25mm alum square section radius edge because this way will be much stronger and look heaps cleaner
. The cradle rails need 3 presses each to fit up which isn't hard now that I have a bending die machined up to form the rails. Reusing the standard Y frame is a bit more work but not impossible. My engine jig and 4 billet engine mounts turned up during the week, and my 97 model cr500 engine should be here in 3 weeks, so things are starting to get a move on. I will post photo's up soon. Rob
lambofgod85
If you are looking for opinions on K&Ns, Don't do it! they may breath better than a well oiled 2 stage Uni but they will also pass more than air through.
personally I like the sticky filter oil, FFT is my choice, BelRay also works.
I don't care for the uni oil, it's probably really good for oiling and use it at the track same day but for me it's too thin and will drain out of your filter if left too long.
Good luck with your build!
lambofgod85
lambofgod85
lambofgod85
lambofgod85
lambofgod85
Cradle rails
Here are some pictures of my build. The rail in these pictures is a sample of what I need. I have been playing around with different angles, radius bends and shapes of the rail to make it look nice. The Y frame still has to be lifted around 15mm to fit into position. I cant do too much more until my engine and new FMF pipe arrives from the states.
lambofgod85
lambofgod85
lambofgod85
lambofgod85
lambofgod85
lambofgod85
[/img]
[/img]
[/img]
[/img]
[/img]This my Cr500 A/F donor bike..........died as a 4stroke, Reborn as a 2banger.
[/img]My Cr500 97 Engine and parts turned up from the states today, very happy with it. Now its bolted into the frame ready for cradle to be made. I have got 3 weeks off work next week to finish frame mods, so there will be more updates and pictures.
[/img]
[/img]
[/img]
[/img]
[/img]
[/img]
