I'm now contemplating swapping the '96 motor in the '05 chassis which has brought me here! I've been digging for a while but I've yet to see anyone that has made the swap without butchering the right side cradle to clear the side cover and peg mount casting. I've seen a few swaps but it seems like most skip over this important part and fail to photograph this trouble spot. SO, I'm here to see if anyone has some insight on what exactly is involved in making this work.
Plan 'B' is to snag a 2004 CR250 frame and build off of that. I have access to one relatively cheap and if the above option is too involved I might go this route. From what I've read this would be as close to bolt-in as it gets.
Thoughts, comments, ideas?! All are welcome as I'm here to learn. As a little background I can rebuild/repair anything on the bike, 2 or 4 stroke. I can cut and grind but don't have access to welding equipment so that would have to be outsourced. Thank you in advance!
