Does anyone have a steely 2001 cr500 frame sitting around that they can get some accurate measurements of the head tube dimensions?
overall bottom to top measurement of the head tube, and how deep the bearing race bores are? I'm trying to avoid disassembling my bike to get the measurements.
Doesn't have to be an '01 but I would prefer the newer year race sizes, I think all balls shows their kits fit 90-01, so any of those years should work.
looks like the bore diameters should be 47mm on top and 51mm on the bottom. the depth of each bore would be helpful.
would anyone mind taking some head tube measurements?
- louis mielke
"Don't worry, it will grow back!"
Re: would anyone mind taking some head tube measurements?
louis mielke wrote:Does anyone have a steely 2001 cr500 frame sitting around that they can get some accurate measurements of the head tube dimensions?
I believe i have a 2001 steel frame from a CRE500:
head tube height is 184.5mm
lower bearing bore is 14.8mm depth x outside diameter 47mm
upper bore depth is 14.8 depth x OD 47mm
Allballs kit #22-1018. I bought it for a 1994 frame has 2 different bearing diameters of 47 and 51
this kit fits: CR125 90-92, CR250 90-91, CR500R 90-01, XR650R 00-07
i can strip down my 1994 frame to confirm, i need to do it anyway.
Building my own and always waiting for parts
- louis mielke
- other
Hey, do you want to sell me the ADR compliance plate, mate ?Scotty wrote: I believe i have a 2001 steel frame from a CRE500:
other wrote:Hey, do you want to sell me the ADR compliance plate, mate ?Scotty wrote: I believe i have a 2001 steel frame from a CRE500:
No way thats going to happen, sorry
- other
Yep, it was a pretty tongue-in-cheek question . . . . That thing is worth more than gold to a standard CR500 owner !Scotty wrote:other wrote:Hey, do you want to sell me the ADR compliance plate, mate ?Scotty wrote: I believe i have a 2001 steel frame from a CRE500:
