Its a 03 Service Honda they used a 02 CR250 so its Ca green stickered. Pro taper top clamp, Tag lower, Braking over sized wave roter, ASV levers, Pro taper bars, Acerbis bark busters, Clark over sized tank, stock tank, One Industries seat, TM Designworks slider roller and guide, New white UFO plastic, 18" Excel rear rim, Devol rear disc gard and radiator braces, 15oz flywheel weight, PC spark arrestor, The motor is stock with a wiseco piston standard bore. The frame cracked and has been repaired, the swingarm has a ouch in it. It is missing the airbox, reed cage, carb and pipe. $3,000 firm
209-480-7900
Paul
