Aluminum Sleeved, Nikasil Plated Cylinders
I've been backed up with everything the last few months. 2strokeforevers cylinder is out at plating and theres work done in it I won't be posting pictures of :wink:. This one is for inventory if guys come looking for one. Its sitting at basically stock porting right now and i'd tailor it to how the guy wants it before sending it to be plated. The surfaces were cut to clean making the cylinder .002" shorter than stock.
Cylinder with aluminum sleeve
New OEM Cast sleeved cylinder
sweet, any ETA? i havent rode a real bike for almost 3 weeks :cry:
whats it gonna cost to replate if (when :shock: ) i run dirt thru it?
what piston will i be running? im thinking maybe oem (534 grams total) cause its lighter than a vertex (547 grams total)
unless wossner got their act together
what clearance are you hoping for?
cmotodad
Post by cmotodad »
After the alu. sleeve is in, is there much of a weight loss?
About 1.3 lbs :wink:
cmotodad
Post by cmotodad »
Do you feel any difference one the bike? I know that motor weight seems to have a big effect.
Not sure, the last one we did I didn't run it back to back. I'll also have them on a short stroke crank that's lighter and 447cc. Should be an excelent combo.
cmotodad
Post by cmotodad »
I like the idea of smaller displacement. Still think going more square bore and stroke would make a very good combo.
Motorrad
Post by Motorrad »
cmotodad wrote:I like the idea of smaller displacement. Still think going more square bore and stroke would make a very good combo.
Nikisil CYL... square bore and stroke.... next you guys will want power valves.... :roll: Its a honda.. not a COW...
Very sweet mod there Roost.. We have discussed this for the K5's in the past...
Cholo
Post by Cholo »
Very good job Adam!! :wink:
anakin7583
Re: Aluminum Sleeved, Nikasil Plated Cylinders
Post by anakin7583 »
Roostius_Maximus wrote:I've been backed up with everything the last few months. 2strokeforevers cylinder is out at plating and theres work done in it I won't be posting pictures of :wink:. This one is for inventory if guys come looking for one. Its sitting at basically stock porting right now and i'd tailor it to how the guy wants it before sending it to be plated. The surfaces were cut to clean making the cylinder .002" shorter than stock.
please, when can I buy the aluminium sleeve??
thank you!!
anakin7583
please, where can I buy the aluminium sleeve??
thank you!!
bigpower
Post by bigpower »
I had thought of doing that years ago, glad to see you doing it. The one thing I wanted to do was make a sleeve with a bridge intake . A bit more support back there would in my opinion double a pistons useful life.
