My 500 is leaking coolant from the weep hole in the water pump cover. I bought a water pump kit and replaced the seals and gaskets, and it is leaking seemingly just as bad as it did before I touched it. Pretty sure I put the seals in the proper directions, and the water pump shaft was NOT grooved or galled in any way.
What else could cause this issue?
Leaking coolant
- NightBiker07
Leaking coolant
- NightBiker07
It was installed flat side in. I am familiar enough with how seals work to know how they are installed
I got another seal and replaced it, hopefully it will cure the issue. the shaft is perfect, so the problem doesnt lie there...
