Wide Ratio Tranny Gears
USMC 500
Post by USMC 500 »
Hey Hoons!!.....I got the 92 CR500 motor because at $600 for motor, carb, electronics it was a steal. However I am aware that I also ended up with the close ratio tranny......Gonna look into getting the 4th and 5th gear out of the 93-01 CR500. Can anyone tell me what the part numbers are for those gears? Or at least how many teeth each one has?.....Everywere I look refers to them by number of teeth and not as 4th or 5th gears.
freeride588
Post by freeride588 »
What are you using the bike for
Kevin
Nodge
Post by Nodge »
I would just run a 15 tooth front sprocket.
$13.
Find any post by Roostius Maximus,
Click the red in his signiture, and there is a ton of CR500 parts info and pictures
USMC 500
Post by USMC 500 »
freeride588 wrote:What are you using the bike for
I will be trail riding with it.......Don't care too much about racing at top speed across the desert. I don't want it to be a dog either....
freeride588
I have a 91 which is the close ratio as well and it does good in the dezert with the 14/48 gearing I run. I would run what you got and go from there.
Kevin
USMC 500
Post by USMC 500 »
sounds good.....I have the 14 tooth front and I have a 50 tooth on the rear right now.
Then you WANT the close ratio tranny....
Rhino89523
Post by Rhino89523 »
I have a 1992 as my motor , everything else is part of the week to keep her going. I run everything with it and it's fast enough to make your eyeballs float in your head from trail to dune, just run it.
