will 06 crf 250 suspension fit my 97 triple clamps?
Wondering if this was possible? Looks the same diameter? Use front forks wheel brake...the get up....[/u]
									CR500!
If you understand
Well then
You understand
						If you understand
Well then
You understand
				scooter5002
The forks from my 04 450 fit right into the triples on my 99.
If memory serves either the upper or lower is a couple thou too
small. No problem just spread a little more with the screwdriver
to slide it in. Also the forks were slightly further apart so there
is less axle sticking out on the pinch side. Again not a problem.
However, you cant do this swap. I was told so. By some douchebag
on VitalMX. Said you cant put "new" technology suspension on
"old" technology motorcycles. It wont work, and messes up the
bike.
   After I claimed that it improved my 99
by leaps and bounds, told me that it wasnt possible and I was
full of shit. Even though he never rode it. So you better not do it.
bike.
 After I claimed that it improved my 99 by leaps and bounds, told me that it wasnt possible and I was
I did it, it all lines up well. the 97 triples are a bit wider than the 06 crf 250. hince the 97 forks wont go in 06 clamps...but it has tightened up nicely. there is still a little gap on bottom clamp and nuts are tight! cant wait to ride it and see if it really helps...will the rear shock fit...lol..JK
									CR500!
If you understand
Well then
You understand
						If you understand
Well then
You understand
				scooter5002
Actually I think I checked the rear shock difference. One is longer
than the other maybe the 04 is the shorter of the two. I think
maybe pivot bolt sizes were different too. Altho that could be fixed
easily enough. If memory serves I believe a guy on here ran into the
same problem as you and he cut up Monster cans as shims.
BLASPHEMY!!! I'd use beer cans. Likely 1 wrap is all you need
take up a couple thou and youre in BI.......ness! Good luck let
us know how it turns out.
I loving it!
The front suspension off the 06 makes all diff in the world! It will be a nice hold me over til i get the AF frame moded
									CR500!
If you understand
Well then
You understand
						If you understand
Well then
You understand
