Cylinder head help
kevin_s
Cylinder head help
Post by kevin_s »
Ok,I'm building an 86 engine,the cylinder head i have is off an 98.
Can I use the 98 head on the 86 engine if I use the later thin head gasket,or will i still be down on compression?
It will have the same compression as the head you use. 98 on 98 gasket will give the compression of the 98.
Cylinder port timing and the lack of scallops in the exhaust will give a pinch more. Nothing to worry about
kevin_s
Post by kevin_s »
Ok,thanks Adam. :cool:
seanmx57
Post by seanmx57 »
Me thinks it won't run as good as a 86 would with the right head.........
kevin_s
Post by kevin_s »
seanmx57 wrote:Me thinks it won't run as good as a 86 would with the right head.........
I have not cc any 500 heads but the look pretty close when they have their respective head gaskets.
86-thick head gasket
98-thin " "
anybody have any cc # handy for the two heads?
seanmx57
Post by seanmx57 »
Adam had pics up somewhere that showed the smaller dome on the 85/86 head.
