1996 CR250 Ignition
1996 CR250 Ignition
Just picked up a 1996 CR250 ignition from 500riders.com for my buddies bike. It didn't come with the fly wheel, can anyone tell me if a 98 CR250 fly wheel will work with the 96 stator?
AFC Build link
Ok thanks for the heads up. The 98' flywheel is already on it's way so I'll post my findings once it gets here.cmotodad wrote:Not sure about flywheel working or not. The 96 is analog and the 98 is digital. Most likely will not work.
Anyone have a flywheel that will work on a 96 ignition shoot me a PM
AFC Build link
Will do as soon as it gets here, thanks.2strokeforever wrote:i think it will work, they look identical
just line up tdc and the pulsar the same as the 500 stuff
AFC Build link
Thanks thats good to know. We'll have to keep the look out for one that will work on the 96 ignition.Hall911B wrote:I have a 94 F/W and a 97, the I.D. is different between them. The 94' should match your 96 and the 97 should match your 98.
AFC Build link
