Well, it's been a long while, but I've managed to get a few things accomplished with this baby. Several other projects have gotten in the way, otherwise it would've been done by now, that's my story and I'm sticking to it. Rue hooked me up with some much needed parts off his 88, FMF pipe, triple clamps, shock, linkage, subframe, fenders, and misc. frame grommets.
 As you can see in the before photos, the subframe was tweaked beyond repair. Well actually, someone repaired it, but forgot to straighten it first.
 I ended up having to cut the right side downtube off the 85 subframe and put it on the 88 subframe. I didn't do my research before hand, but in the end, it looks respectable. I have the subframe cleaned up and in  primer, now working on the frame prep. I was in the process of removing several broken bolts from the frame and found a broken tap as well!
 WTF??? A real bastard to remove, I have tried needlenose and vise grips with no luck, it's broken off flush. Other than trying to shatter it, anyone know of another way to remove it?
 I was hoping to have the frame primered today too, but this is holding me back. I have the engine on the bench, torn down and cleaned up. Cylinder and piston are standard bore and in awesome shape.
 I ordered new rings just for the hell of it. Bottom end is in great shape too, I really expected it to be neglected judging by the home it came from, but I really don't think the guy ever rode it (since he couldn't start it.) Performed the water pump "refurbishment" with the good ol' JB Weld, and the water pump is getting new seals and bearing while I'm at it. The water inlet was JB Welded to the cylinder and shattered when I removed it. It's the newer style with inlet on the right front, not on the back of the jug. Ordered one of them too, working on cleaning up the mess and will probably have to drill and install heli-coils since the threads are filled with JB too. This one is starting to be more than a "budget restoration", but when the hell can you ever stick to the budget? Hopefully one of my "other" projects sell soon so I carry on with this one.
 (YES, I KNOW)
