Cylinder head question
freeride588
Post by freeride588 »
My cylinder head looks like a grenade went off next to it a bunch o tiny indentations all over. Should i run it or is it time for a new head. Thanks much
Kevin
Yea.... a new head and a replacement snap-ring.......
I can re-cut that chamber. I'd likely buy the head if you were just going to replace it also.
Tharrell
Post by Tharrell »
What do you suppose happened to it, bearing let go maybe?
Sucked garbage through the intake?
freeride588
Roostius_Maximus wrote:I can re-cut that chamber. I'd likely buy the head if you were just going to replace it also.
Nice if you want to pm me what you would charge to cut the chamber and also what you would give me for the head. I also had a couple other questions for you as well. thanks alot
Kevin
freeride588
Tharrell wrote:What do you suppose happened to it, bearing let go maybe?
I think someone before me had blown up a piston. The connecting rod is an ims so the cases have been split before.
Kevin
