Suspension work?
- NightBiker07
Suspension work?
did some digging in the approved vendors section, couldnt find anything.
Does anyone have any recommendations for sending out suspension to get worked on?
I can rebuild the seals/sliders on forks, but thats about it.
Unless someone has done rear shock rebuilding and can offer words of encouragement.
These guys make it seem easy http://www.blazeofgloryoffroad.com/2010 ... shock.html
I just found out the rear shock on my 250 is blown. the clickers for rebound and compression are set at FULL hard, and the bike rides softer than my 500AF does set to full soft.
Odd thing is, I LOVE the way the 250 handles. It flies straight, lands straight and soft and doesnt bottom unless I overshoot or case, takes whoops like a champ and rides plush as can be on the trails.....And ive had more than a few people ride my bike. All have commented on how soft it is, but none have complained about errant handling. I'm not sure what to make of it.
I've used this guy a couple times now.
http://www.moto-pro.com/
He works out of his garage. Avid rider. Does his homework complete with telemetry on at least 6 different new bikes a year. Good prices. Stellar results.
- NightBiker07
they in good shape? I dont really want an old shock on its last leg, then i'd be stuck with 2 blown ones and still have to get one rebuiltseanmx57 wrote:I got a bunch of 2000 CR250 shocks I should sell off, if you need one let me know.
After riding my 94 250 this weekend I have come to really aperiate what Steve (the owner) at Shock therapy has done to my AF for track riding.
I always figured set it up for outdoor MX and it will be good for the trails too.
www.shocktherapyracing.net
Tell him I sent you or you race with Vet X racing and he may give something off.
- NightBiker07
I do have a manual for my CR250. But the manual also makes it look easy to tear the top half of the fork apart......And I thought you needed special equipment to charge the shock?100hp honda wrote:replacing bushing and seals on the forks and shock is easy. can do all of it on a saturday. did 2 honda and a yamaha so far. havent tore into my ktm yet but it will probly be easiest of all. something tells me you dont have a manual or you wouldnt be asking if its difficult
- NightBiker07
I thought the charge process was really touchy, to where trying to fill and check with a tire fill/gauge would throw it off? There dont seem to be too many suspension shops around here. Ive yet to see even one, and the dealerships farm out a lot of work.100hp honda wrote:its all pretty easy. with oem honda book you wont have a problem. after its back together most any shop can refill nitrogen. 5-10$ depending what shop
				scooter5002
Do NOT use a tire gauge.  You need the special valve/gauge all in one tool.  It's WAY more accurate and precise in the delivery of Nitrogen.  Basically, it screws onto the Schraeder valve on the shock, and you turn a t-handle to crack the Schraeder.  The nitrogen tank is turned on, and the regulator (like the ones on oxy/acetylene tanks) is preset to the pressure required in the shock.  Turn the valve on the filling tool, and the shock is filled.  The valve is closed, then the t-handle is closed, sealing the shock closed with EXACTLY the amount of nitrogen you need.  IF you watch the shop do this, it will all make sense.  Tire guages are for tires, Nightbiker.  Not this job.
I'll openly admit that aside from changing a few fork seals, I'm pretty happy to just drop my stuff off at a local shop (Machine Racing LGS) that is known for suspension work, and let them handle it.
Ive found I can pretty much bolt it back on, set the say and go ride, I have barely ever touched a clicker or messed with them afterwards.
- NightBiker07
Kind of what I figured. I'm going to buy a shock off of seanmx57 in the future. if he sells them before I get to it, then Ill send mine out to get rebuiltscooter5002 wrote: Tire guages are for tires, Nightbiker. Not this job.
- NightBiker07
Sort of what I was thinking. I'm also gonna dig more into a shop that rebuilds suspension locally, Gotta support the local guys when we can!100hp honda wrote:its your money but im saying a suspension rebuild is child play. factory connection is $100, plus parts, plus round trip shipping. 2 bills should cover it
I have not used this guy but I plan on using him as my secret weapon! His name is Pete Russell in Spokane, WA.  Company  NOST web http://www.nostsuspension.com/
During NAHA Rnd 1 a gentlemen turned me on to Pete, he had him work some vintage suspension and gentlemen was Very impressed could and not believe the difference stating "Pete is very Creative and thinks outside the box"my kinda guy.So I called Pete up and it just so happened he had just returned from a dyno test lab some big well known facility where NASA and Ferrari test suspension...Well I guess his suspension tested beyond anything the facility has EVER seen.
Like I said have not used him and guess no longer a secret but I still would like to use him as a weapon tell Him Kevin Bergquist the hill climber from California sent you...Its all about putting the Power to the Ground
DIE TRYN!!!
YOU MAY BE A PIT BULL BUT
I WILL CHEW ON UR ACHILLES TENDON LIKE A CHIHUAHUA.
- Kartwheel68
If you dont want to revalve and all you want to do is replace the seal head, doing a shock is actually easier than doing forks. Its not rocket science. The only thing that can not be done with just basic tools is refilling the nitrogen. There are several places on the web with step-by-step instructions on how do do a KYB/Showa shock with photos. If the shock is off and on the bench anyone can do it in under an hour, less the nitrogen. I can do a shock rebuild with no revalve in about 30 minutes if its already off the bike and on the bench.
very well said. and he has the honda book for assistance. not sure exact parts youll need, probly better to tear it apart first and see. several o rings on there you might want to replace. not a bad idea to get new nut for the end of the damper rod, mine was peened over so i got new one. new seal but on yours i dont know if its part of the rod giude. micro fish shows a seal set so i dont know. be good time to do the top spherical bearing if its shot. dude its easy just tear into it and get a list for what you need. make sure the bladder is still good.Kartwheel68 wrote:If you dont want to revalve and all you want to do is replace the seal head, doing a shock is actually easier than doing forks. Its not rocket science. The only thing that can not be done with just basic tools is refilling the nitrogen. There are several places on the web with step-by-step instructions on how do do a KYB/Showa shock with photos. If the shock is off and on the bench anyone can do it in under an hour, less the nitrogen. I can do a shock rebuild with no revalve in about 30 minutes if its already off the bike and on the bench.
- Kartwheel68
Just order a complete seal head, it already has all the o-rings and seals installed, several companies like Moose make them.
Pivot Works also sells a complete kit with seal head, bump rubber (which probably needs to be replaced and you have to take the shock apart to do it, so it would be wise to do it while you already have it apart), and reservoir bladder for $89.
Take off the nut, slide off the valve and shim stack, slide off the seal head, reinstall new seal head, valve and shim stack in reverse order.
- NightBiker07
Is that what is wrong though? i mean, it doesnt leak oil, but the suspension is extremely soft, like the clickers are at full hard and it has no effect whatsoever.Kartwheel68 wrote:Just order a complete seal head, it already has all the o-rings and seals installed, several companies like Moose make them.
the rubber bottom-stop is about toast, so it will need replaced for sure.
I have no reason to think the shock has no oil in it, the reservoir still gets hot when I ride, and i would think if it was oilless, in the 4 years Ive been riding it it would have siezed up by now.
around here we dont use aftermarket moose or pivot works
    . that chinese garbage dont fly with me. j/k dude
. that chinese garbage dont fly with me. j/k dude   . dont want to step on toes but i recomend he go with oem stuff but either way i dont care its his money. you may be right, seems like that seal head deal is the complete package of stuff needed. theres other wear items besides that seal that should be replaced while you in that far though. that brass bushing deal i was talking about. also rubber orings on the little clicker deal of the resorvior. they dont move but no sense in reusing $2 orings that are 10 years old. i think theres is 1 or 2 more $2 orings on that piston mechanism  that i would replace also but thats just me. maybe i went over board on my shock rebuild but i also replaced the bladder. compresses in/out and sits in oil continuosly. for $10 i wasnt gonna reuse the old one. regardless if you only replace a couple things or alot of stuff your still going to save tons of cash over what a shop would charge.
 . dont want to step on toes but i recomend he go with oem stuff but either way i dont care its his money. you may be right, seems like that seal head deal is the complete package of stuff needed. theres other wear items besides that seal that should be replaced while you in that far though. that brass bushing deal i was talking about. also rubber orings on the little clicker deal of the resorvior. they dont move but no sense in reusing $2 orings that are 10 years old. i think theres is 1 or 2 more $2 orings on that piston mechanism  that i would replace also but thats just me. maybe i went over board on my shock rebuild but i also replaced the bladder. compresses in/out and sits in oil continuosly. for $10 i wasnt gonna reuse the old one. regardless if you only replace a couple things or alot of stuff your still going to save tons of cash over what a shop would charge.- AlisoBob
The shock oil is bypassing the valving by going around the piston.NightBiker07 wrote:Is that what is wrong though? i mean, it doesnt leak oil, but the suspension is extremely soft, like the clickers are at full hard and it has no effect whatsoever.
The #1 reason for losing the piston seal is the shock bore is fudged up....
I would take it apart first, before spending much money on it.
The nut is peened on, DO NOT just run it off with an impact... it will destory the threads.
- NightBiker07
if the bore is destroyed, what are the options? new shock?AlisoBob wrote:The shock oil is bypassing the valving by going around the piston.NightBiker07 wrote:Is that what is wrong though? i mean, it doesnt leak oil, but the suspension is extremely soft, like the clickers are at full hard and it has no effect whatsoever.
when you say destroyed, arre you talking bore scoring? I have the skill but NOT the tools to check for bore defects like warpage, out of roundness, etc.
Peened on nut. does it have to be cut off?
I'm not against tearing it apart, I just dont want to get it back together and have an ill-handling creature
