I bought one of these recently and really can't believe I waited this long and put up with those friggin' Arrow staplers for all those years. "Heavy Duty" my ass!
You go to drive a staple and one side goes in, the staple twist a bit and you try to hammer it in or use a screwdriver to get it to go. What a PITA!
Well, no more. This thing drives them in perfectly everytime.
At 3/8" crown, the staples are a little narrower than stock (OEM is roughly 1/2") so I use two staples, one above the other, at each staple point. No big deal, 10,000 staples for around $6. I use the 1/4" leg length.
I bought mine at toolbarn.com but they can be found for cheaper at Amazon.com.
Great tool!
****CAUTION***** There is no safety on this gun. Pull the trigger and a staple comes out. So, remember what Mom said, "It's all fun and games until somebody gets hurt".
Features:
- Uses standard Senco® & quotC" Type, 22 Ga., 3/8" crown staples rom 1/4" to 5/8" long
- 1" nose extension for limited clearance fastening
- Small and light weight for ease of operation
- Rear exhaust port channels air and tool oil/condensation away from work
- Steel top cap for durability
- Driver Guide moves back with magazine allowing jams to be easily cleared when magazine is open
- Convenient bottom-load magazine holds 185 staples
Specs:
- Fastener Type: 22 Ga. 3/8 Crown Staple
- Fastener Range: 1/4" to 5/8" leg
- Magazine Capacity: 185 Staples
- Operating Pressure: 70-120 psi
- Firing Modes: Trigger
- Height: 6"
- Length: 9"
- Weight: 2 lbs.
