helping a friend with his 500. Top end has about 2 hrs on it. Reason for tear down is a shifting issue, but noted some marks on the piston and cylinder. Ring end gap is .016".
Any ideas on what caused this and how to correct. Some of the scratches in the piston are .005" or so. with eyes closed marks in cyl cannot be felt.
mine did same thing but got exh side also. main 1 step small was my final conclusion. not sure what happened on yours. chamfers look fine so i dont know
no point in making a 10min deal a 7hr head scratcher. alot of bullshit to figure it on paper. im not even sure how to do it. wouldnt you still have to pour something in the dome then subtract the amount the piston protrudes into it then figure was volume in in the headgasket bore and blah blah blah. ill stick with oil in the plug hole
from start to finish i doubt the oil thing takes 10min. piston at tdc, smear grease, bolt on head, measure amount of oil poured in hole. divide that by your total cc. shazam dont get no easier than that . watch and learn grasshopper
I told you to buy the bore gauge.... so you have that right?
So measure the bore.
With that measurement, the distance from the roof of the exhaust port to the deck, the head gasket thickness, and the head volume you can compute the true compression ratio.
THEN, if you change ( or just want to run the numbers) on a new setup like a different head or exhaust port timing... you just punch the numbers into your calculations...
and the dome shape on the top of the piston dosent matter?
500cc of displacement, crammed into a 50cc chamber ISNT a 10:1 motor.
that could depend on the pipe and rpm if you want to get technical, to figure out what exactly is going on in there is gonna be tough
if it was put together and it didnt shift i would wonder if whoever put it together knew what they were doing
maybe he assembled it dry, without oil and the first time it ran it scored a little?
maybe crooked bore and/or tight piston
Last edited by 2strokeforever on November 13th, 2011, 10:31 pm, edited 2 times in total.
100hp honda wrote: at this point your kinda looking really dumb
Can you even read?
AlisoBob wrote:...With that measurement, the distance from the roof of the exhaust port to the deck, the head gasket thickness, and the head volume you can compute the true compression ratio.
I'm starting to think Gsslen IS your Dad... Why dont you go on Springer, and have a "Baby-Daddy" test done?
