It's not leaking yet, but it has me worried. Naturally, the part is discontinued from Honda.
Does anybody know if a later model water pump drive shaft will interchange? Anybody have a good used one for sale?
I also found some corrosion in the water pump housing. Very little, though, a few pin holes that I filled with JP Weld. This is the infamous magnesium cover, right?
I was wondering if I could paint the inside of the water pump housing with some kind of (epoxy?) paint to seal it off and prevent further corrosion? Sound like a good idea?
Also, there was some gunk in the cooling system, gel like stuff that dried to a scaly, powdery white coat. Should I run some cooling system cleaner through to clean that out? Will those automotive cooling system flushes work, or will they eat up the magnesium?
Lastly, what is the best coolant to run in these bikes in terms of corrosion prevention?
All my other bikes are air cooled ('82 Husky 430, '83 Maico 490, '84 CR500), this is my first water cooler, so please excuse the stupid questions...
Thanks!
