oversized fuel tanks ?
coley13
Post by coley13 »
sorry my search came up with 1400 results. i've seen gen 3 with oversized fuel tanks before but not sure what needs doing. Do these bolt straight on without any modification? i was thinking of getting IMS tank from rmATV.. Is there anything else i need to know before dishing out my hard earned...
i think it's 3.2 Gal by memory, so whats that about 12 litres ?
Stock and oversize Gen2/3 bolt on w/out modification.
The Clark gen 3 needs the heat gun in at least two places. In addition to that also did the sides where the head is and where the head stay is. Probably didn't have to for the stay but had my reason.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
iggys-amsoil wrote:The Clark gen 3 needs the heat gun in at least two places. In addition to that also did the sides where the head is and where the head stay is. Probably didn't have to for the stay but had my reason.
Interesting - I didn't have to do any for my Gen2. Although I am running an IMS tank. Gen2/3 are typically the same - or so I thought. Thanks Iggy.
coley13
Post by coley13 »
do they come with cap and petcock, or swap over stock or have to buy seperatly ?
Gmbond
Post by Gmbond »
Ims tank on gen3 has much more spark plug clearance than the clarke. I had the options of both and I liked the ims better on my converted bike.
The clarke tank on my gen3 250 sat on top on the spark plug. I had to heat the tank and shim the front mount to allow use of a standard plug that would be able to be changed trailside. And that was on a 250!
