Calvin Pollet runs a small company that manufacturers high performance parts for ATV's, motorcycles, snowmobiles, and a few other uses. His company does not sell to the general public, but Calvin is on here to answer questions and tell you the closest dealer in your area if you are interested in the parts he produces.
He started with a 95mm bore in this design, and as soon as the new larger pistons are available, we could see bores as large as 106mm from this design. The CR500-Liger cylinder was designed to be used with a bolt-on adapter plate to minimize case modifications and still allow the transfer tunnel size to be increased and repositioned for optimum performance increases.
Welcome Calvin, from all the Hoons at Banned!
