I had a fun but BLOODY weekend in Big Bear
91 CR 500, Ca. plated.
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
that looks bad hope you get well quick
did the tubliss flat cause you to crash?
the only weakness i found with mine is if you are running low pressures and nail a big rock right on the rimlock it will make a unhappy noise and possibly get you a flat, the bonus is if you get a flat grab your plug kit and check by the rimlock, only had 2 flats in 8 months (plug and 5 min later im back riding), before i poped a tube a month
also if you have a tubliss use lots of soapy water when installing the tire and it will hold air forever.... no soapy water and it will leak
- Rhino89523
Rhino89523 wrote:Heaviest duty tube you can find.
talc in tire
lose rim strip and cover with duct tape a few wraps cut at half tape width.
lose nut on tube outside rim
run 2 psi more than you want to
Done, so few flats in 30 years it doesn't even deserve mention, I ride mostly rocks.
That's how to do it.
- gregrobo
x3 never had a flat in the bush and we ride the lot rocks sand forrestsRhino89523 wrote:Heaviest duty tube you can find.
talc in tire
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
98 yzfr1
2010 rmz 500af
01 banshee
liked the Tubliss because I was able to run 11 PSI with no pinch flats for
1 1/2 years.I think tore off a knob. I will still trail ride with them, but plan to
run a Bib up front and a lighter bike for the next event.
Got this for Fathers day.
I want to learn to ride what wins in Baja every year.
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
Thank,s Bob.
My nose is OK, they took the stitches today.
5 more days for the staples in my knee and stitches in my elbow.
I feel good, but it sucks having 2 black eyes.
Craig.
Craig.
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
- Rhino89523
Hey Craig,
Hope my post didn't come off wrong and I meant to put heal up quick in the post and went back today and realized I hadn't.
So first and foremost, heal up quick and sorry for my rudeness.
I rode that bib moose stuff or whatever its called once, it was not my bike but I didn't like the feel the way I like air. My other post was basically just the way I roll and that the combo has rarely failed me front and rear.
Thank's no worries, I will try what you recommend.Rhino89523 wrote:Hey Craig,
I think with a lighter bike it might work for me, with my XR650,
I found it would turn well and stick to rocks with 9-11 PSI.
It also worked better in soft sand which I also ride.
With Tubliss I was able to run 9-11 PSI. without pinch flats.
Thank's for your help Craig.
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
How about a crash from last year at Big Bear.
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
09 CRF 450X
XR 650L
2000 CR 250R
2006 CRF 150F
