90hp Cr500 on fleabay
DieHard2Smoke
Post by DieHard2Smoke »
http://cgi.ebay.com/ebaymotors/Honda-CR ... 500wt_1182
90hp cr500 and all he did was mill the head and add a pipe :roll: :roll:
or maybe his billet kickstand is what added the other 35 hp....
Farchar swore blind his stock-ish 500 pulled 94 horse on the dyno :roll: :roll: :roll:
Re: 90hp Cr500 on fleabay
DieHard2Smoke wrote:http://cgi.ebay.com/ebaymotors/Honda-CR ... 500wt_1182
I have one of those kickstands. It's only worth 10 hp tops. Or do I need to rejet for it?
You need to re-jet........sewing needles worked best for me......I was able to get 19 extra hp out of my Pro Moto billet kickstand......but I also replaced my muffler bearing and installed the purple power band.
I sent him this:
Do you have a Dyno sheet for the claimed HP numbers? And, are these numbers at the crank or at the rear wheel?
It is very difficult to get even 80 HP out of a CR500, even with porting, high compression, reeds, pipe, silencer, modern carb and modern ignition. So your numbers are impressive, if in fact these are from a known good Dyno.
We'll see what he says! :roll:
NightBiker07 wrote:We'll see what he says! :roll:
He'll say his flux capacitor was out of alignment and didn't do as well as expected on the dyno. But his SOP dyno says otherwise!
:lol: :lol:
:lol: :lol:
And he said:
interesting points. the numbers are only rough estimates from my engine builder.
My reply:
Well, I am no expert, but I have worked on enough motors and know enough about CR500's to know that you should find a different engine builder. He is easily 25HP overestimating the output of your engine.
Sounds like hes been talkin to glen....
