Milling Machine
maddog1927
Milling Machine
Post by maddog1927 »
Bridgeport Series 1 Variable Drive
Sony DRO
Full set of R8 collets plus holder
X axis power feed
Single shot lube system
6" Vise
8" Rotary table
Misc Tooling
Phase converter (Static)
$2500 Delivered Phoenix metro
Possible deliver to the Lakeside AZ area, maybe to LA area, depending on what trips I have coming up.
A nice addition to any shop.
:cry:
maddog1927
Roostius_Maximus wrote::cry:
Adam, thanks for your condolences, but I am not getting out of the milling buisness, just doing something that makes my wife nervous, I amgoing for a newer model with tighter tolerances.
Old mill
New mill
:wink: sweet
thats pretty reasonable $ if that dro, vice, clamp set and rotary table come with :shock:
if i was still in the area i would check it out. too far away now
roost251
Post by roost251 »
Maddog, could you recomend any repair shops in AZ, I have a bridge port like yours(the one you are selling) and it needs new spindles bearings and a general going through. Thanks!
maddog1927
roost251 wrote:Maddog, could you recomend any repair shops in AZ, I have a bridge port like yours(the one you are selling) and it needs new spindles bearings and a general going through. Thanks!
PM sent.
You could also call tom moore of moore tool and equipment. he seems to give good recomendations. He told me who to call to move the mill, and it worked out well
roost251
Post by roost251 »
Thanks again for the info, I lucked out on moving my mill to az as my friends had a fork lift and I have a good carhauler to put it on. Thanks.
hey, I'm looking for something like this....
http://www.wttool.com/index/page/catego ... teChampion
my others are .200" shaft tip with a flat end, i'd prefer one the same, no ball end.
Any ideas on where to look?
