83 CR480 Parts needed
BrianPaul69
Post by BrianPaul69 »
I just picked up an 83 CR480 and this is what I need so far :
Rear shock with spring and rubber reservoir mounts ( Preferably one that doesn't need to be rebuilt )
I also need the complete rear brake setup (panel as its called) with cable and foot brake.
Airbox with filter, cage and bolt (not cracked or melted please, mine already has that )
Mudflap ( no cracks, mine already has those )
Plastic preferably OEM ( rear fender, both side covers)
After market pipe and silencer (preferably without a lot of damage)
Swingarm chain slider
90.5mm piston kit (Don't want used)
Rod and crank bearings / seals
