cr500 engine upgrade questions
rynwilliams
Post by rynwilliams »
I have a 1986 CR500 that i am currently rebuilding.
I have managed to get a new 2001 clutch casing to upgrade that so changing the clutch will be easier.
The crank need sorting as there is a lot of play but i am having a hard time sourcing a conrod for the 1986 engine as it is shorter.
My question is if i were to buy the later cyclinder could i fit the later conrod and piston to my crank?
Also is it possible now i have the later clutch cover to upgrade my clutch to the wider type in the later engines?
Any other recommendation would be welcome.
call me later today
204-325-9853
Adam
rynwilliams
I am in the UK.
nmdesertrider
Post by nmdesertrider »
don't know about the UK but you can get an 86 OEM rod from any of the OEM dealers
03 CRF450/85 500
rynwilliams
I have tried a few places here but no luck, anyone know of a place that will ship one to the UK??
rynwilliams
I have just placed an order with service honda.
Can anyone confirm if the later wider clutch will fit as a replacement for the standard 1986 clutch. I have replaced the clutch side casing with a brand new one from a 2001 engine.
Thanks
Sounds like you're all set to go, if this chart doesnt confirm what you're asking, post it and i'll try to help you out.
rynwilliams
Yes i have that pdf document which is a great help.
I am wanting to get a complete new clutch for the engine, if i buy the parts (basket and clutch kit etc) for the later clutch 1990-2001 will i have any problem fitting it in my 1986 engine. I do have the 2001 clutch case.
Thanks
