Carb set up for Pikes Peak Hill Climb.
TheToeCutter
Hey fellas, Im doing Pikes Peak this year and thinking about how Im going to set up the bike. It presently has a 41.5mm PWK and with all the accelerating I need to do from hair pin turns at 9000 to 14000ft I think its just going to be too big, and will fall flat. Im thinking of getting a 36mm PWK, and an "intelajet" http://www.thunderproducts.com/IntelaJet.htm anyone think this is a bad move?
Personally, I think you will need as much air as you can get, at high altitude with less oxygen. Guys run retarded high compression too to compensate.
Use a air foil in the carb maybe if your not satisfied with part throttle transition.
Of course gearing, and other internal engine mods all play a great role in the end.
TheToeCutter
heard guys had good luck with this, they make them for bikes too, just have to call, looking into getting one
intelajet wont be that useful because you gotta take a hand off the bars to adjust and you arent 100% sure exactly how much you leaned it....
i have the intelajet and like it for not having to pull the carb to adjust, i dont use it while riding
http://www.holtzmaneng.com/
torque monster
torque monster
I use an ATACC for Pike Peak - that is what you want. Still need to figure out you jetting for 9500 as that is approx. starting line elevation.
ho good does it work? is jetting spot on always? assuiming its setup right....
and if you lay your bike over will it overflow just as well as normal or will it load up excessively?
was looking into getting one but couldnt find out about the overflow issue, no one there could give me a guarantee that it wouldnt flood the shit out of my bike every time i lay it over
