A. it would be badass and
B. It would give me a chance to really mess and experiment with porting, building an expansion chamber, and even getting diffent ratio gears machined for the transmission. Where horsepower and whitenuckle fun are more important than it being super easy to ride and spin good lap times.
I have an 85cr500. I want to take the motor which is very fresh despite needing a clutch cover, and set it aside to put in a beer can later on down the road. I dont wanna waste a perfectly good MX motor
I want to find an 83 cr480 to put in this frame because from what I have read, it is the aircooled motor to go with if you want a 5 speed. Aircooled motors look more awesome, getting rid of the radiators is a must, and with this being a street bike I dont see overheating being a problem.
I have a CB750 frontend on it right now for mock up, but I will need to get new forks. I think The stance will handle well, the CB triple clamps move the front end out a bit. If any of you guy see a potenial problems let me know!
The rear section will be built into the frame, not a bolt on. I have a shorter shock off some street bike I might try and run but the twin shock idea i had in the picture is a no go. so the rear shock mount is probably going to get relocated
The tank is also off of the CB750, but will probably use a CB350 tank or something similiar. that tank is way too big looking.
So some questions I have are: What should I do for lights? Could I go a rewind on the 480 like the thread in this section?
What would be the best ignition to use?
Is a 39mm or a 38mm lektron a better choice?
Does anyone have a lead on an 83cr480 motor? I plan on rebuilding it, so locked up ect is a ok.
Has anyone ever cut custom gears for a transmission before? I am a CAD operator for an electrical company by trade and I am wanting to carry this shit over to engineering parts. The idea of figuring out the right ratios to work with my HP and torque curve and then desiging them and handing specs over to a machinist and getting back something that no one has gives me a hard on. The only thing better would be someday being able to machine the parts myself. Boner time.
Does anyone else think this sound like a kinda cool project? Any feed back would be rad.
