Two thumbs up (unless you are like my uncle, one thumb and a stub)
Makes tire installation a lot easier, holds the bead down.
If you change a lot of tires or put on a few ice racing tires these things are worth it. I just installed a set of Marcel Fournier two way ice tires last nite and these helped out quit a bit.
Also I have the cheap K&L tire stand, it was worth it as well.
Motion Pro Bead buddy
Iceman
2002 CR500 AFC
FMF fatty, V-force, 39PWK, Dyno Port engine, EGT
