Cleaning a neglected af frame
Gmbond
Post by Gmbond »
What does everyone use to clean up their bikes?
I've got a chassis that looks as though it was put away with dirt and mud on it. The aluminum is etched and marked from the mud damage.
I've used aluminum wheel cleaner and scotchbrite pads before with reasonably good results. I'm after a stock looking finish not polished
Thanks
Paulie is the "Brushed Finish" king.....
mr2ace
Post by mr2ace »
AlisoBob wrote:Paulie is the "Brushed Finish" king.....
Can you share his technique?
maddog1927
Post by maddog1927 »
I use scotch brite, WD40 and wipe with a clean rag
mr2ace
Post by mr2ace »
Paulie, whats da 411?
kdizzle
Post by kdizzle »
Comet and a green scrub pad work well, also a wire wheel on a drill works good if you are after that brushed look...
mr2ace
Post by mr2ace »
A lot of love :bling:
maddog1927
pstoffers wrote:
mr2ace wrote: .
so does this mean Paul is not going to share his technique?
:wink: Can't share all my secrets....
Gmbond
Post by Gmbond »
Don't know what Paul uses to make his frames look so great but I have discovered for my one ugly frame (was put away muddy by the dpo and has mud stains etched in)
Wd40 and scotch brite pads seem to work well. And then turtle wax chrome polish/ rust remover with scotchbrite pads to finish. Seemed to give a decent brushed finish. Maybe a little smoother than stock but thankfully not polished looking.
maddog1927
been doing the scotch brite / wd40 thing, I will have to try your second step.
For a bit more of a brushed look try a more course scotch brite. I have 2 boxes of SB pads. They are for the resturant industry, leaning pots and pans. One is "general purpose" and is about the same course as the back of a common kitchen sink spounge, the other is marked "extra heavy duty" and is alot more course. I give my frame a good rub down with the general puropse, then "touch" it with the extra heavy duty as needed to give it the brushed look.
yota
Post by yota »
when I got my frame back from Mike it had been heat treated and cooled in a salt water mist, looked like it had been in the bay. I used navel jelly to clean it and then dried it and used a wide stainless steel brush in the direction of the grain. Looked stock to me when it was done.
09 TTM CR500AF
08 KTM 200 XC
08 Ducati Hypermotard
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
