IMS Desert Tank $110
Stock Tank $75
PJ Carb $50 (Damaged, broken outlet, carb works fine just be aware it is not perfect)
Rear Brake Assembly $50
Front Brake Assembly $50
Thist Throttle $20 (Does not include Slide)
Seat $60
Others - Make Offer
Rear Supsension (Shock/Spring)
Left/Right Radiator
Swingarm
AirBoot
Front Wheel (Some dings on Rim)
Triple Clamp (One Stripped bolt for Front Fendor mount)
Left/Right Forks
Front Disc Gaurd (White)
New Rear UFO Black Fendor (some scratches)
Stock Tank $75
PJ Carb $50
This is damaged, please be aware of that.
Rear Brake Assembly $75
Front Brake Assembly (includes broken lever) $50
Thist Throttle $20
Seat $60
Radiator
Swing Arm
Front Wheel
Triple Clamp
Forks
