2002 CR250 Ignition
2002 CR250 Ignition
Anyone using the 02 CR250 Ignition I have some questions.
Are the RECTIFIER and REGULATOR needed ?
I have a 98 CR250 flywheel as well and the pickup point on that flywheel
is approximately 9mm further left (counter clockwise) with the key ways lined up,than the one on the 02 flywheel.
Would this preclude the need to elongate the stator mounting holes
to get more advance?
I have 3 stator plates here right now, 98,00,03 i believe, they all have different lockouts, a 1, a 4 and a 3.
I'd phase the pickup edge to not overlap the trigger and call that 0. if it needs advance i cant tell you forsure, look thru the timing profiles in the 250 ignition thread or get it on the dyno.
I'm waiting for the thaw to dial mine in
Cool thing with the 2002+ ignition is the electric powervalve circuit puts out enough juice to power an led headlight and led taillight.
Not enough to throw any real light but enough that even daytime the led headlight looks lit up like an hid ( doesn't project it but looks bright)
This in my case is enough to pass tech for enduro use.
NO, the pickup could be on the oposite side, it dosent matter where the pickup is, as long as your using the cdi that goes with it, it will have the same advance as it did on a cr 250, which should be within 5 degrees from the original cr 500 mapI have a 98 CR250 flywheel as well and the pickup point on that flywheel
if your thinking about the pickup at all your just confusing yourself more, what you really want to know is the mapping of the ignition
Hum.......you sure about that?2strokeforever wrote:NO, the pickup could be on the oposite side, it dosent matter where the pickup is, as long as your using the cdi that goes with it, it will have the same advance as it did on a cr 250, which should be within 5 degrees from the original cr 500 mapI have a 98 CR250 flywheel as well and the pickup point on that flywheel
ya, think about it, the woodruff key is in the same spots on both crankshafts, the ignition dosent know (or care) whether its bolted to a cr 500 or a cr 250, its job is to fire at whatever its mapped to,Hum.......you sure about that?
the fricken pickup could be on the other side, upside down, it dosent make any diffrence, because the ignition was propgrammed to work with it like that by THE HONDA ENGINEERS, so is all you gotta worry about isfiguring out the map for it and deciding whats the best compromise
so heres what youd do if youre running the 2000 250 setup, look at this chart, see that the 250 setup has 4 degrees less max timing, but the same @ 8000, so you gotta decide if you want to leave it that way, or advance the timing to get that max advance the same, then the timing will be advanced 4 degrees @ 8000
the ONLY other way the timing could be off if the stator mounting bolts are in a diffrent spot, that will throw it off, to check put motor at tdc, lines on your flywheel, stator,engine case will line up... now take it off and put the 250 setup on without moving the flywheel, if those lines dont line up then you need to make them line up.... 1999 is good
try it with, then unplug themBut... Are the RECTIFIER and REGULATOR needed ?
while I do believe 2002 and later setups can be made to work, the following article says they are different.
I know the flywheels on the 125 and 250 are keyed differently along with having the pickup coils mounted in different spots
I have ran the cr125 cdi on my cr250 stator and flywheel but I have not tried the cr125 stator and flywheel because the pickup is in a different location and creates mounting issues.
So I do not know if it is timed the same as the cr250 and 500
Basically if the key way on the 2002 cr250 crank is at the 12 O'Clock position while at TDC like the cr500 then it should work fine.
write up from here:
http://www.ekartingnews.com/viewtopic.p ... c&start=75
Hi Guys
I will add some explanitory photographs tomorrow as my camera batteries are dead!!
After Sid's post and various e-mails, I think that it is best if I clarify completely the situation with regard to fitting a '99 to '01 generator (8-pin plug) to an '02 onwards motor.
It appears that some people may have taken one of my statements that this was a straight swap a little too literally. The generator (rotor and stator) is a straight swop but there are timing differences which although mentioned in other posts may not have been 100% complete or clear.
Simply put:
When swapping/fitting a '99 - '01 generator to an '02 onwards motor and with the standard lower index plate in place, the ignition trigger point will be advanced by 12 degrees.
To correct this you can either:
1. Run the rotor without the key and replace the rotor 12 degrees clockwise relying on the taper to hold the rotor.
2. Remove the lower index plate and elongate both top and bottom adjustment slots to allow anti-clockwise rotation of the stator by 12 degrees. (this is entirely possible, but requires also removing the little hump near the top slot to allow sufficient elongation)
3. Programme the programmable CDI box to take account of the different offset (retard the whole curve by 12 degrees)
4. A combination of the above.
We tend to run the key in place, remove the lower index plate and run the stator fully anti-clockwise in it's standard slots. In this position the flange of the top mounting bolt will be sitting hard against the side of the little "hump" that helps retain the cable clamp. This gives 8 of the required 12 degrees and then we make the small programming change (4 degree retard on the whole curve) to finalise the correct setting.
Incidentally as a bonus moving the stator on it's slots decreases and cable stretch from the stator to the case grommet.
When fitting any new ignition and/or generator we always verify the firing position by testing either on the rig or on the engine using a strobe light. It is entirely possible that this will vary up to a couple of degrees from installation to installation.
If you are using an engine builder, ensure that he has verified the ignition curve either in your fixed or programmable CDI box relative to crankshaft position.
Anyone purchasing a complete system or CDI box from Viper Racing UK, will receive a fully checked unit and detailed fitting instructions.
We personally do not recommend the use of the standard Honda CDI box for kart use. But I know that Roger Miller, for one, has had some success with an '03 box
I hope that this clears up any ambiguity.
As always if you have any sort of question or doubt, please don't hesitate to ask and be as specific as possible.
Specifically Sid
The SPI '99 CR250 box will work with the '99-'01 CR250 generator when fitted to an '02 onwards motor using the methods above. Same applies to the standard Honda box, but this would not be my recommendation. In these cases I would say just elongate the slots to allow a 12 degree anti-clockwise rotation of the stator from the standard indexed position. Simple
Best Regards
Ian
_________________
Ian Harrison
write up from here:
Hi Guys
Simply put:
Specifically Sid
Best Regards
Ian
_________________
Ian Harrison
