Does a 94 crank case will fit with a 92-93 swingarm?
xtremeslide
Post by xtremeslide »
I sold a bike to someone he told me that the right crank case is broken
and we are looking for a spare,i thought that the cases from 91 to 01
will fit the 93 swingarm but he says that the 94 and up cases are wider
than the black one and don't fit with the 93 swingarm.
What do you think are the cases the same and only change the colour
in 94 or if i want to fit a 94 motor in a 93 bike we should do an extra
work?
The references are different.
CR500R
V-MAX 1200
physically the crankcase is the same from 1989-2001
the clutch case 1990-2001
they did change the part number for powdercoated or non, and the 1998+ RH case has a larger area behind the kicker spindle to make it stronger.
They all mix and match without any issues
xtremeslide
Thanks roost
CR500R
V-MAX 1200
