Parts options
Parts options
I have an 88 motor that has a bad clucth basket. Can I install a newer side cover so I can install a newer basket? If I can, what other parts do I need to replace to make the new basket work?
Gen 2 A/F - 88 engine
04 CRF 450
04 CRF 450
No sweat mano!I just bought the clutch basket, inner hub, and the bolts just the other day.
Here is HPD link:
http://www.hondaparts-direct.com/default.asp
Here is HPD link:
to answer your question, to do the upgrade, you need the side cover (the small clutch cover and waterpump cover and parts are all the same) clutch basket, inner hub, clutch discs, t/o pushrod and bearing. the outside plate, screws and springs can all be reused. Be aware that some of the honda dealers have started sending the new parts when you order the old ones.
I just discovered that when I bought my clutch basket that I got the new style basket that is about a i/4 inch deeper than my old one (how the hell I didn't notice that when I was comparing the two I never know)
But anyways I will now be getting a new side cover for what looks to be $128.70 at HPD also a new clutch rod for $11.19.
While I am at it I am going to get a new water pump shaft, seals and bearing.
Danny are you sure the the small clutch cover and water pump cover are the same because HPD shows different part# for an 88 to a 95 (which is what I am looking up).
yes, they are the same, or atleast will work. make sure you also get the t/o bearing.
I've got 2 '86 waterpump covers and they both fit on my '93 side cover. I think the PNs changed because they used a different material.
I seem to remember a difference with the dowels, like the newer ones are longer or something, but they will interchange.
I ended up just getting a Hinson basket from Dennis Kirk
http://www.bannedcr500riders.com/board/ ... php?t=1246
Decided why buy all those other parts when mine were still good.
