max comp
allmotor09
max comp
Post by allmotor09 »
which is the maximum of compression (in cc's) for cr500 combustion chamber, which runs on race gas (114oc pur with nitropropane mix)
Last edited by allmotor09 on December 29th, 2010, 7:47 pm, edited 3 times in total.
:britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali: :britincali:
kdizzle
Post by kdizzle »
depends if you are running a rekluse or not.
allmotor09
i'm running stock clutch component
:shortbus:
fastkart
Post by fastkart »
I don't see why 18:1 isn't reasonable, as long as you use an iKat and Coolhead.
Maximum compression cc's is 491, it will run very nicely with any mix of race gas and nitromethane.
However I dont agree with the above post, I think the roost boost is the only way to get a spark hot enough.
kdizzle
Post by kdizzle »
ill have pity... :twisted: :twisted:
Im not sure of the CC's but with a compression tester if you are blowing 180-185PSI your doing good. mine requires 50/50 race gas/92 at 180PSI
Send it to GSS, Glan is the CH3NO2 god.
He'll "Nitro-Port" it for only $1,ooo
Same as his trailport, playport, 1/2 race port and fullrace port
allmotor09
I believed that you not good opinion of glen
allmotor09 wrote:I believed that you not good opinion of glen
When you mix gasoline with nitromethane you get goo, and it wont run...... so whats the difference?
nitropropane mixes with gas...
2strokeforever wrote:nitropropane mixes with gas...
Hell ya it does!!!!
fastkart
Post by fastkart »
I've been using 8oz/gallon for a while now. Good stuff!
allmotor09
sorry aliso bob I'm mislead while writing
its not a nitromethane but nitropropane
rsss396
Post by rsss396 »
14 or 15 to 1 is the most I would run
That is UCCR (uncorrected compression ratio)
AlisoBob wrote:Send it to GSS, Glan is the CH3NO2 god.
only difference i could ever find was the squiggle on top the piston :confused:
nitropropanol*
Mad Dog
Post by Mad Dog »
Tough crowd.......
kdizzle
Post by kdizzle »
i know it... my GSS motor runs like a sumbitch still.. However I have no idea what level of porting i have... :shock: :shock:
Mad Dog wrote:Tough crowd.......
I was kinda thinking the same thing
allmotor09
woww, really a great help, laughter of the world :x
