What are you guys using on yours? I have a magellin gps mounted to the bars and i hate it. I personally could care less if i have it, but massachusetts law requires one.
I was thinking of perhaps a dash from an xr? Are the speedos cable driven? Maybe i can swap the front wheel to get the drive hub?
What else are you guys using?
Speeo for cr-500
- redrocket190
- redrocket190
http://www.acewell-meter.com/
The model is a 37XX and you can download a manual from the web site. Looking in the box I found a plastic mount that the speedo sits in that gives you additional indicators if you want to wire them up (fuel, turn signals etc.) You'll see they provide a Y-shaped mounting plate that uses the tab on the leading edge of the CRF-X triple clamps. The OEM odometer has the same mounting bolts. If you are using CR or after-market clamps you are going to have to get mounting bracket or fab something. The off-road market does all sorts of mounting brackets for GPS etc.
Michael Stiles
2007 Honda CR500R-AF
That's a cool looking unit.
It's better than the other one you were looking at Bob.
After the ride and my gps batteries going to "low batteries" warning I turned it off for emergency purposes so out goes the speedo or directions.
I can't tell if turn signals are on. and I couldn't see the stock trip-o-meter how many painful miles I had left.
This one is next
This one is next
