Cheap 12v D/S Battery
Different discipline.... same Hoon behavior
$8
http://cgi.ebay.com/1-pcs-12v-1000mAh-N ... 4aa733fb79
Powers the lights for quite a while. Crazy cheap!!!
"SOLID Bro!!"
Post by "SOLID Bro!!" »
You buying back up batteries? just to have on the shelf?
kball1313
batts
Post by kball1313 »
I bought those before and they work pretty good to maintain the lighting on the street. Had one that size in my 650r as well as the steely tard. I found a guy selling backup house alarm batts that are sealed 1.2ah batts and are barely bigger. That one seems to hold up better when i'm stuck in traffic because the output of the SH ign struggles to keep up at low speed, even though all my lights are led aside from the headlight.
I'm still trying to adapt a high/low beam shutter style xenon projector to my cyclops on the af motard that I saved from my days working with BMW. The cheap-swap in a hid bulb into a regular lens don't even compare.
Not the same seller, but same dimensions. The AA style cells seemed to not hold much of a reserve for a 1000ma rating.
http://cgi.ebay.com/RHINO-12V-1-2-Ah-Se ... 114wt_1141
Here's another one that the KTM/Yama guys are starting to use to cut some pounds off e-start machines. Lithium Iron- the Shorai one, lot more $ though
http://batterystuff.wordpress.com/
[quote=""SOLID Bro!!""]You buying back up batteries? just to have on the shelf?[/quote]
Naaaa.... the one that came with the bike is old and only runs the lights for a minute.....
Baja Designs wants $40 for their pack
This chinese cheap-o ran the headlight on high beam with the blinkers on for 5 minutes before I shut it off.
Seems to do the trick
same thing as i got on my bike, except mine is from tusk, and $24
http://www.rockymountainatvmc.com/produ ... lyId=26640
Algava
Post by Algava »
got one
