I really like the Sunline V1's Pecker turned me onto. They will be good insurance against a broken lever 50 miles from the truck ruining my day....
Only problem is these levers went not designed to fit a XR650R.....
Heres the brake side. I had to reprofile the master cylinder casting to match the radius in the lever... simple enough.
Also had to shave a little off the stop to make it fit correctly. A sharp file did both in 5 minutes.
Here it is all reassembled. The small silver post is adjustable to move the lever in or out. Great levers!!!!
The clutch side was a little more difficult due to the lever girth, the decompressor lever sitting on top, and the snuggness of the handguard.
Heres the top of the lever shaved down a bit on a belt sander
Hers everything assembled. Notice the lower portion of the hand bucket is filed for clearence too. Its snug, but it all fits.
I also added some bar plugs that I had laying around. All in all, a big improvement!!
I also have a different top bar clamp to add....
Heres the stock clamp. Bars are WAY behind the fork centerline. Not good for tall, fat, Hondapotumus riders.....
Heres the new clamp. Moves the bars forwards 2", and up 3". Should do the trick.
Next I'm servicing the forks, adding springs, and taking it out for a test ride before the big Mojave Trail trek.
