Needle Sudco PWK 39.5?
- Bomberpilot
Does anybody know which is the stock needle in the PWK 39.5 that Scudo sells?
I have one but i have no possibility looking at it at the moment
I heard that i should rather go for an DGN or DGL. What i read DGL is better for heavier tuning (a little more fat) whereas DGN is good for stock an soft tuning? Please correct that statement if it is wrong.
Btw: I can't find the Scudo website anymore - what happened to them/it?
Thanks
Thomas
Thanks
Thomas
Last edited by Bomberpilot on December 3rd, 2010, 6:18 pm, edited 1 time in total.
- Bomberpilot
ok i spelled it wrong, thats where the problem comes from
thanks buddy.
so it seems like the pwk coming from sudco has the DGH needle (but i found it only in general, not specificly for the cr5 - so perhaps there is a special cr5 carb jetted different w/ different needle).
can anybody confirm the DGH needle? So and most of you guys thinks this is too fat right?
@kdizzle: got ya, i have studied it before but it is always helpful to have!
- Bomberpilot
- Bomberpilot
supermotard use... also on the streets.
on the track trying to have as much full throttle as i can but from very slow to fast through the whole gear an rpm range.
on the streets through the whole rpm range with full throttle.
but when you have to follow the road speeds only at 1/4-1/2 throttle were it shakes alot and also seems to be on the fat side.
but normally i would say for street use i would rather be a little on the fat side, but i would just go a little fatter on the main jet...
what do you think?
what do you think?
- Bomberpilot
I run the DGL in the middle
