Electrosport / Service Honda Ignition Parts
redrocket190
Post by redrocket190 »
I have...
(2) Rotors
(2) Digital CDI boxes
(2) Stators
(1) Wiring harness
(1) Battery
(1) Regulator
These parts are either 4 or so rides old or unused. I assume that you will have read the comments here and on the other site about the rabbit kick starting method and the need to set the air gap correctly. Basically if you do the latter the former is not needed and it will start one kick.
also...
(1) OEM CRFX front headlight
(1) OEM CRFX rear fender and tail light
(1) OEM CRFX switch gear
I am having a clear out and my AF will not be used with lights etc. so this is all surplus. Any reasonable offer accepted. PM me.
Michael Stiles
2007 Honda CR500R-AF
other
garage clearout
Post by other »
PM sent
other
Post by other »
Hi Michael,
I sent PM, just checking whether you still have any of these parts. I will buy Rotor, CDI, Stator, Harness and regulator if you do. In fact, if you want to gety rid of it all as a job lot, I'll be up for that too, (except battery, of course).
