BODY - PWK 398BK06
NEEDLE - N 82 M
can i use the jets/needle from my PJ on the bike now ???
thanks
lance
choke assembly looks exaclty like the PJ setup without the needle tip...Roostius_Maximus wrote:its is from a snowmobile?
big knob on the choke, no hose on the carb bowl, downward 90degree inlet?
that needle is like one i have from a sled pwk is why i ask
so can i use that needle or should i just swap over my needle from the PJ ? i really want to try the DGN needle but dont know which way people are going with them (leaner or richer)....Roostius_Maximus wrote:then you're golden
as i said the 20:1 was for break in and i used to use 20:1 in all my old bikes (gt80 and 81 yz465) ill be running 32/40:1 in this bike... i have 42, 45, 48, 52, 55 pilots so ill keep playing..iggys-amsoil wrote:Wow 20:1 Help save the enviroment![]()
Less is more. 50:1
I would start with a 48 or 45 pilot
use the same needle and main from the PJ. or DGN probably better.
Roostius_Maximus wrote: ride it like you f'n stole it
Having quality machine works helps .....pstoffers wrote:Roostius_Maximus wrote: ride it like you f'n stole it
Thats how you do it right there!!!
yep. using special jets is gay.Roostius_Maximus wrote:i'd break it in like bob did:
1 - same jetting as he usually runs
2 - warm it til the rads are hot
3 - ride it like you f'n stole it
more cash in your pocket. thats about itiggys-amsoil wrote: less is more
hate to tell ya this but oil content has nothing to do with smoke, spooge or revabilty. when you have correct a/f ratios it makes no difference if you have 16:1 or 70:1, wont be smoke or spooge and revs will be crispqkenuf4u wrote:its broken in now so i can cut down on my oil .... less smoke, less spooge at pipe/silencer connection (gotta get the rad hose tomorrow and fix that) and just cleaner reving/running...
plus gotta get the PWK jetted now..![]()
