How hot for bearing replacement
98cr500rider
Question is how hot in degrees Celsius do you need to heat the engine cases to remove and install new main bearings?
I often read about heat them up enough and the old bearings will fall out and new ones out of the freezer will drop right in.
I don’t do this every day so just to be clear is this true quite literally or an exaggeration, will they drop in without driving them in with a drift or is this myth?
If so how hot is enough and still safe for the cases, I intend to use an oven with a temperature gauge so please be accurate if you know, not just hearsay.
Just out of interest has anyone got a video link of this being done?
Thanks for any info on this
both mine dropped in, i used a toaster oven at 350f, and i froze the bearings too
and if you do need to tap them in make sure you are pushing against the part thats going in, not tapping on the middle of the bearing if youre putting them in the cases
never read any info regarding the honda. direct info from ktm manual says: heat housing halves to 100-150 C. bearings should fall out on their own at 150C. if they do not then tap housing lightly on piece of wood. clutch arm bearings might need blind bearing puller. they rarely wear out though so might not need to replace them.
if you use map gas or propane carefully, you'll see the aluminum sweat, once that goes away its ready
south central hoon
- 2strokekyle
2strokekyle wrote:Don't just hammer them in/out, it will screw up the bores the bearing rides in. Hot cases plus cold bearings = no interfereance, at least for a second.
put the bearings in teh freezer over night and the cases in the oven at 300F
