PC type 296????
PC type 296????
i have a PC type 296 spark arrestor silencer, and i would like to know if i am loosing power from it. its pretty loud, louder than my 125 with a shorty
i repack it properly every 2-3 rd ride with pink insulation
if its loud does that mean im not losing power????
kdizzle
Post by kdizzle »
you repackit every 2 to 3 rides? Is that what you meant? thats a bit OCD me thinks!
Lets see here. Me New since 05, never repacked it. :shock:
The piston is three times the size. So it should be ten times as loud.
Problem solved. :lol:
Sorry for being such an idiot, just having some fun.
As I understand it, rap it tight and get as much in there as pos....
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
the reason i repack it so much is because on my 80 / 125 it made a HUGE diffrence in low end torque... yes they were jetted right and crank seals were good, but i cant notice anything on the 500, maybe it dosent mater on the 500, i cant notice it, or it spins so much i cant notice the extra power
seanmx57
Post by seanmx57 »
get some silent sport string type packing and repack it every 100 hours or so
OR
continue to work for $0.25 per hour and use free pink crap
the pink stuff is EXACTLY the same as any FMF packing i have ever seen at the dealership... and new pink insulation is waaay better than fancy stuff that is full of spooge
on my 80 i used the FMF stuff a few times and i could tell when it was dead, and it lasted just as long as insulation... the only diference is it was $10 a repack instead of 0
back to the original question does the PC silencer rob power?
seanmx57
Post by seanmx57 »
Insulation that is used in a wall to keep you warm is not the same as the stuff you use in a silencer. The cheap stuff won't take the heat and will blow out real quick.
Yes a blown out silencer is loosing power. messes the jetting up too,
i dont know how you pack your silencer but i dont have any insulation getting blown out... or heat damage
the unburnt oil making the packing into a giant turd is what looses power, or if its getting blown out because you cant pack it right that will loose you even more
seanmx57 wrote:Insulation that is used in a wall to keep you warm is not the same as the stuff you use in a silencer. The cheap stuff won't take the heat and will blow out real quick.
i took apart a new fmf powercore2 and im certain it was nothing more than average fiberglass insulation. took apart a PC also, seems like it was 304 model or something like that. i think it was a synthetic fiber crap, probly the special packing you speak of.
the fancy "asbestos" mat that came on my bike was soaked in spooge after 2 rides, because of crappy jetting... and somehow it had heat damage, jetted rich too :roll:
pink insulation has held up so far tho
you need to work on your jetting if you have that much unburned oil soaking up your silencer. I would start with the needle.
gregrobo
Post by gregrobo »
pink bats insulate houses
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
seanmx57
Post by seanmx57 »
The pink stuff may look the same, but it's just looks. The melting temp is 500 or more degrees higher on the good stuff.
With a carb running well a silent sport pack with last a VERY long time, at least 20X over cheap house insulation.
got the dgn needle today :D
does anyone have any tips on how to get the center perforated piece to lineup with the end cap on a spark arrestor when puting it back together??
i stick my finger up there and line it upon a normal silencer, but the spark arestor gets in the way
