AlisoBob's Gen 4 A/F Conversion
I made 2 peices about 1" long out of 1/4" plate and drilled and tapped holes, then welded those. I'd show you a pic, but my hosting space got all f-ed up. It was essentiallt like the oem mount and loaction, only higher up.
- NightBiker07
I'm assuming you never did plumb the spars?
I would like to do something like that to my bike, but add a valve so they would be a switchable reserve so i knew when fuel was getting low.
AlisoBob wrote:Its in there.... you flip one side to side, and go buy one from a cr250.....
Don't you mean one from a CR125, Bob?
OK this might save some confusion when stuffing a CR500 engine into these frames.
The Std CRF250 04-09 uses a 49mm on the left and a 59mm on the right, with the CR500 engine get a 54mm for the left side and you are done.
The Std CRF450 02-04 uses a 49mm on the left and a 54 on the right, with the CR500 engine swap right to left and get a 59mm for the right side and you are done
The Std CRF450 05-09 uses a 46mm on the left and a 54mm on the right, with the CR500 engine swap right to left and get a 59mm for the right side and you are done.
The Std CR125 02-07 uses a 54mm on the left and a 59mm on the right, with the CR500 engine you are good to go as is.
The Std CR250 02-07 uses a 49mm on the left and a 54mm on the right, with the CR500 engine swap right to left and get a 59mm for the right side and you are done.
Part# for the 54mm bush is 52142-KZ4-J40, left side of swingarm.
Part# for the 59mm bush is 52141-KZ4-J40, right side of swingarm.
If any of this is incorrect, please let me know so I can change it before any mistakes are made.
I had to do that to all 3 of the gen3's I have done...
conversion
My 2004 CR250 conversion did not require this. I was running a 5.4 spring too . Maybe I got lucky ? ? ?
DPinDet
DPinDet
"Trees are for traction"
