Calling flywheel weight owners
What do you run for an ignition cover?
Dad bought weight to try on my 500. He doesn't like how it won't tractor around quite like his WR and just kinda dies if you try to. Anyway, the thing won't fit under my aluminum Honda Racing ignition cover. Looking for suggestions. Does ShanMan have any more of his snazzy covers?
Rob, I might be interested in that weighted flywheel after all.
Rosco-Peeko
Post by Rosco-Peeko »
Ok, lemme know. Mine is a tight fit under a Boyeson Ign Cover.
I have a 15oz under a ShanMan cover and it fits under the stock cover to.
Found out the motor in my AF has one and it wil fit under the stock cover but not under the alluminum one I got from CR500Riders when they made them.
redrocket190
Post by redrocket190 »
I have run a 13 oz Steahly weight under a Boyesen "Honda Racing" ignition cover with no problems. My weight backed itself off despite being correctly torqued down. I hear you need to Loctite the allen screws that pinch the stock rotor.
Michael Stiles
2007 Honda CR500R-AF
StinkFinger
Post by StinkFinger »
Dude, I've got a 15oz Steahly that I will give you. I hated the sucker so much that I jerked it off after 2 hours. It fit fine under the stock cover. I can bring it to Odessa.
Thanks all. It has been installed under the stock cover I dug out of my box o crap. Dad thanks you all.
My opinion remains the same. It's better without it. Dad still wants to try it.
thestuz
Post by thestuz »
instead of using a weight, i just geared mine up to a 14/46. that seamed to help with traction and gave me longer gears.
if you wanna sell your alloy ign cover, give me a shout.
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
crf69
Post by crf69 »
stealthy 13 fits good behind
boyesen
They should take the warning labels off of everything and let stupidity sort itself out.
