85 cr500 question
- Jimmah
85 cr500 question
I can pick up a non running 85 pretty cheap locally. I have a 99 cr500 that I picked up to do a AF swap on. I'm not really interested in the chassis at all but would the engine be good to have? From what I can tell this engine doesn't share to much with the 99. Are the engine mounts at least the same where I could use the cases for mock up? Thanks guys.
1999 CR500 Steelie to AF project
2001 CR250
2002 XR80R
2005 CRF50
2006 CRF150F
2006 CRF450X
2008 CRF50
2001 CR250
2002 XR80R
2005 CRF50
2006 CRF150F
2006 CRF450X
2008 CRF50
im sure the engine mounts are the same location. cylinder is lower so you have to take that into account when doing the Y. head is lower so also consider that when making a headstay. i would just take the '99 engine out and use it for mock up since thats the engine youll run anyways. why you want a old junk bike ? for spare parts or engine mock up or fix and ride it ?
oh and the swinger bushings are different size, i forgot about that. allot of fuckin hassle just to use it for mock up puposes.
