CPI pipe -where are the conclusive results?
well after reading 18 or so pages of back bitching and hearsay, I still found no conclusive answer.
How was it and where is the dyno sheet?
I don't speak peak, cause most people run their engines through more than a single 500 RPM range.
how fat was the curve?
lets stay on topic ....please?
- thestuz
yeah we were gonna do a dyno sesion but it was organised at the end of last year. think we all partied too hard over christmas and it got forgotten in the haze of hangovers. but yeah id still be keen as to see it happen,ive just been busy lately doin a fireblade build
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
01 CR500
98XR600
94 FIREBLADE
ESTABLISHED 1977.
- glen howell
Since im unbiased ill put my bike up as the dyno mule so no one can say the results were tampered...but I get to keep the winning pipe...
Sack up biches...
Sack up biches...
- CR500R7
M.F.D.B. wrote:Since im unbiased ill put my bike up as the dyno mule so no one can say the results were tampered...but I get to keep the winning pipe...
Sack up biches...
But it won't do you any good putting it on a YZ450F.
- glen howell
- glen howell
- glen howell
- Gravel Scratcher
Glenn,
How do you balance a single ? from what i have read all you are doing is really moving the vibration from one location to another in the rev range to suite a particular type of riding style or are you balancing something else with the crank ?
So far i haven't been convinced about balancing any single, i'm just curious....
Cheers
Paul
Cheers
Paul
- glen howell
Bob and I have talked about this before. His theory was that the vibes would be worse? I thought it would help smooth it out...glen howell wrote: We have even at our shop rubber mounted a CR-500 what a shaker but the vibes are different.
- glen howell
- Gravel Scratcher
- NightBiker07
so far, it seems that most everyone across the web that has used a CPI pipe likes them, so they make a good product.23champ wrote:so... anyhow, how bout that CPI pipe?
as for the characteristics of what the pipe is designed for, you would be best off calling CP Industries and talking to one of the guys over there about it, and from there decide if the pipe would suit your riding style.
If i had to take a guess from looking at the pipe, i would say it is for a narrower, harder hitting powerband rather than a smooth, mellow one.
it would probably suck for woods, and kick ass for drags, hillclimbing, and riding in the sand in general. It would either suck ass or kick ass on a MX track, depending on how well you could control the bike......
9 HP more from a CPI ?
CPI boast 9hp more....sounds ok from here,surely you wouldnt need a dyno to feel an extra 9hp
THE TOE CUTTER,HE KNOWS WHO I AM!
Re: 9 HP more from a CPI ?
Depends on where the 9hp comes in...stu460 wrote:CPI boast 9hp more....sounds ok from here,surely you wouldnt need a dyno to feel an extra 9hp
speedway501
Ran a bone stock CR500 with a CPI pipe and Pro Circuit 304 silencer on the dyno. It made 58.4 rear wheel hp. Advanced the timing about 2 degrees and increased jet size from 170 to 172. A stock standard CR500 with standard pipe on the same dyno ran 51hp (not the same bike). Both engines were fresh. The Dyno is a Dynamics brand.
same thing i said 3-4 months ago with seat of the pants dyno. everyone laughed it off as bullshit. suckersspeedway501 wrote:Ran a bone stock CR500 with a CPI pipe and Pro Circuit 304 silencer on the dyno. It made 58.4 rear wheel hp. Advanced the timing about 2 degrees and increased jet size from 170 to 172. A stock standard CR500 with standard pipe on the same dyno ran 51hp (not the same bike). Both engines were fresh. The Dyno is a Dynamics brand.
i just built 2 identical boat enignes, 350 chevys, out of the same boat, sameconfiguration, cams ground on a landis, back to back, so there was no bs spec, the grinding wheel was the same size. both decked on the rottler, cranks machined and checked to be the same stroke, heads cc'd + milled the same, same valve job, EVERYTHING. 1 liked 37 degrees, one 31 i think, i have the dynos scanned at work. we swapped carbs to check one against the other, cams were degeed, balancers were marked correct, everything, same ignition ran on both
- sabreguy
If it wasn't the same engine it don't mean shit!speedway501 wrote:Ran a bone stock CR500 with a CPI pipe and Pro Circuit 304 silencer on the dyno. It made 58.4 rear wheel hp. Advanced the timing about 2 degrees and increased jet size from 170 to 172. A stock standard CR500 with standard pipe on the same dyno ran 51hp (not the same bike). Both engines were fresh. The Dyno is a Dynamics brand.
