Britincali's Strocket Ttst....
He's says its got 5 rides left in it...maybe 6....
br_t_nc_l_ sh_u_d _h_ng_ s_ro_k_ts _or_ o_t_n.
That's nasty. Whose bike is that, really?
hahaha! i took the pic but DONT own a 450!
I once had a 14 tooth sprocket with only 7 half worn teeth on it, from doing 5th gear starts.
The rear was a 51 tooth, with something like 23 teeth broken off ( teeth were half worn )
like to see the bike that could do that and still have a clutch in itCR500R7 wrote:I once had a 14 tooth sprocket with only 7 half worn teeth on it, from doing 5th gear starts.
98 yzfr1
05 crf 500 race tech goldies
2010 rmz 500af
01 banshee
98 yzfr1
2010 rmz 500af
01 banshee
gregrobo wrote:like to see the bike that could do that and still have a clutch in itCR500R7 wrote:I once had a 14 tooth sprocket with only 7 half worn teeth on it, from doing 5th gear starts.
A standard 1984 CR500 and 2 standard 1985 CR500s.
The 84 500 was new and used for 2 and a half years almost non stop and never had a clutch problem, 5th gear starts were not used every time I started but was well capable of doing it on a surface with some give.
Don't believe me? try it and see how much grunt these things really have.
I've got vid on youtube of woodshed riding my af dooing 4th gear starts
gregrobo wrote:well i must have a dog cos 3rd is all mine pulls
The gearing you are useing and the surface you are starting on will dictate what gear you will be able to start in.
- xtremeslide
at the begining of the day the chain slider was complete, but missing bolts and flopping around, by the end of the day it was chain resting on aluminum.
oh and both of us got owned by a couple of guys on some wicked kx500s
I have to give him some credit though, we went for a haul ass bowl rolling and he was hauling ass!
BTW, the kx450 and the GSS raceporing w/o nitrous are dead even
Does that mean you are going to buy a CR500AF with GSS raceporting.
OH and sell the KX450F.
depends on the perspective, but I was pretty proud of the kawi. it can hold its own around some quick 500s, thats all. That porting might not have worked out perfrctly, but its still a fast bike.100hp honda wrote:is that good or bad ?dannygraves wrote: BTW, the kx450 and the GSS raceporing w/o nitrous are dead even
had the chain not been grinding into the swingarm the gss probly could take out the kawi
Last edited by 100hp honda on November 28th, 2009, 9:51 pm, edited 1 time in total.
The bike sucked balls this weekend, the last threetrips worth of not missing a beat bit me in the ass.
Chain slider disintegrated
Bolts came out of the mag cover and it was hanging the shifter up
Arm switch for the nitrous broke then shorted out cauing the fuel pump to run when not armed and not run with the solenoids on
Wicked nasty rattling noise on and off througout the weekend
Somethings binding on one of the wheels as it was REALLY hard to push when I unloaded it
Trans locked up on one ride causing it to be stuck in 2nd
Even with that list of broken shit I still got some bitchin bwol rides in, MFDB led one of the fastest dune runs Ive ever been on, every razor was took on a power wheelie
Danny bike is really really nice even tho its green and its a lawnmower.
Justin as usual made me feel like a complete squid with his 4th gear pinned massive wheelie whoop taking.
Those rides definatly made up for the shitty showing at the drags
